12-18-2012 11:52 PM
We are trying to use a second analog module but we cannot get the Robot code to enable the channels. Analog 0 is in slot 1 and Analog 1 is in slot 4.
We've swapped units and know that both work.
I've tried numerous ways to get the code to enable the channels but to no avail.
Is there a key place to turn on the additional channels?
Are they intentionally turned off?
12-19-2012 12:27 PM
The second analog module belongs in slot 5 of the cRIO FRC and slot 4 of the cRIO FRC 2. You should only need to have the module installed when you boot the controller. Does the Imaging tool show the module as installed?
12-19-2012 07:26 PM
Hi
Yes, The analog modules are in slots 1 and 4 of the cRIO FRC II unit.
The Imaging tool shows both so I assume that means that both are working. (its so frustraitng).
I dont see any tutorials that deal with a second analog module or how to enable the channels.
Rich.
12-19-2012 11:23 PM
I think you need to specify "analog slot 2" when programming the 2nd analog module (perhaps you are specifying the physical slot, 4).
geoff
12-20-2012 12:18 AM
No there is no place in the robotics framework code that would allow me to select module 4
I believe the problem is in the Build Dashboard VI. or the DashboardEnables.ctl file
No matter how the boolean enable buttons are set they always get changed to false on Analog Module 2.
Please tell us how it gets changed back to false.
Also why is there a module enable switches for the digital and solenoid modules but the analog modules are only selected at the channel level?
Rich
12-20-2012 11:49 AM
Hey Rich,
Which binary enable switches are you referring to? Is the issue just that you don't get the correct values on the dashboard? If you read the analog values in one of your VI's -like periodic tasks or teleop do you see the correct values update there?
12-20-2012 12:23 PM
I have a feeling you are not trying to actually get the analog module working in your robot code, but rather are just expecting the dashboard to show you the values. There is a fair chance that the default robot code does not send the values of the second analog module. It is simply meant as a starting point for teams to add what they care about, not to send everything and slow down robot code for what most teams don't want. I recommend you try using the analog channels in your code.
12-20-2012 11:16 PM
Kevin
It seems to be a matter getting the enable booleans to set to true.
Setting them in DashboardEnable.ctl does not seem to change the setting in the BuilddashBoard VI
I managed to overide the inputs with Constants set to True and now I see the analog data.
Now I can see the data.
Its not an elegant solution but it lets me observe values and make sure that my sensors are working.
Rich
12-20-2012 11:21 PM
I see, so you don't know how to help.
Thanks anyway
12-21-2012 09:23 AM
Hey Rich,
If you are setting them in DasboardEnable.ctl then after you set them you need to right click and select to make the current value default. Then your selection should persist.
