if you want the button to default as true follow these steps
- Click on the button and set it to true
- Then right click on the button and select Data Operations>>Make Current Value Default
- Finally Select File>>Save All to save the changes
Now the vision loop will transmit images to the dashboard everytime you run the Main.
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
