04-01-2010 09:56 PM
I got the new WET 610N Bridge because our old bridge was having problems.
04-02-2010 10:49 AM
Are you following the directions in in Configuring the WET610N radio from http://usfirst.org/roboticsprograms/frc/content.aspx?id=452? It sounds like you are missing the part about changing the computer's IP address.
04-02-2010 07:05 PM
i did look at that and have yet to use it as it states how to configure to use on the
playing field and my first thought was that would not necessarily apply to using the router at home, but i will try it04-02-2010 07:12 PM
It's the same except that you probably don't have WPA security at home.
04-03-2010 06:33 AM
so what do you think that the "security mode" , "Encrypton" and "Passphrase" should be set at?
thanks
