FIRST Robotics Competition Discussions
No robot communication??
OK - I'm starting a controls a bit late this season - very busy helping sophomore team build a robot.
I played with the controls last year so a bit familiar.  I imaged the Classmate, set the IP addresses,
loaded LAbview, updated Labview, used the FRC imaging tool, downloaded the base line code with
team 3548 in the IP (10.35.48.02).
So, the question is what am I forgetting to establish robot communiction. F1 is enable for this
year (new) but driver station can also be enable with mouse selection.
Must be something simple. Thoughts?
(5,961 Views)
BTW,  if the camera is not connected, will that cause any major issues?
(4,405 Views)
The camera is not needed.  Simply make sure the Enable Vision boolean is false in the Dashboard
(4,405 Views)
Did you update the utilities and the driver station and LabVIEW?
(4,405 Views)
I would make sure you have the Utilities update for this year and that you have your team number set in the driver station.
Kevin Fort
Principal Software Engineer
NI
(4,405 Views)
Accepted by Mentor3548
Thanks for tips. Solution was to disable Microsoft Security Essentials and Windows Firewall on Classmate PC in the developer account.
(4,405 Views)
