01-25-2012 02:31 PM
This is my first year as a programming mentor so cRIO is new for me. The team has a Windows 7 64-bit development machine and I've installed all of the software and 4 updates. I figured out how to configure the network settings and have successfully used the 'imaging tool' (multiple times) to setup the C++ environment by formatting the controller (with FRC_2012_V43.zip).
When I try to create a new connection in Windriver, I get an error message "CPU: PPC603 is not licensed".
Does anyone know how to resolve this problem?
01-25-2012 02:35 PM
Not sure about this one but you may consider also posting your question on the first forum:http://forums.usfirst.org/forumdisplay.php?f=747 or ChiefDelphi as there are a lot more C++ users on those groups.
01-25-2012 03:18 PM
In the remote system tab, the Remote Target properties, there is a "Processor selection. You need to select the "MPC5200".
01-26-2012 01:56 AM
Thanks. I don't remeber any mention of the CPU type in the video or 'C++ getting started' document (perhaps it should be added).
A team member found the solution on his own. He changed the CPU to MPC5200 and created a successful connection before I arrived at the meeting last night.
01-26-2012 12:40 PM
It looks like it's at the bottom of page 6 of the C/C++ Getting Started Guide
01-26-2012 01:34 PM
The screenshot on page 7 shows "Processor: (default from target)". That could be why I missed it...
