FIRST Robotics Competition Discussions
changing slot modulo cRio
I have problems with module 1 slot of the cRio ... I can change the 9201 to slot 4?????
(4,855 Views)
Hey snchb,
You can change the 9201 to slot 4. What kind of issues are you having with slot 1? If its something like a bent pin you should consider calling our support line to process an RMA.
Kevin Fort
Principal Software Engineer
NI
(3,302 Views)
Accepted by snchb
It would be slot 4 for a 4 slot cRIO or slot 5 for a 5 slot cRIO.
While this will work temporarily, it will not be legal for competion. See [R64]. So you need to get to the root cause of the failure.
(3,302 Views)
if a pin bent and no longer recognizes the module. I have to do to process a RMA
(3,302 Views)
A bent pin can definitely cause it to not recognize the module. To process the RMA: Call (866) 511-6285 from 1 p.m. to 7 p.m. Central Time, Monday-Friday
Kevin Fort
NI
(3,302 Views)
thanks for your help ..... I am calling
(3,302 Views)
