FIRST Robotics Competition Discussions
how to use netconsole in C++
I formatted the cRIO and selected the check box for NetConsole. Now I need to figure out how to use it.
How can I include it the C++ code? I added "netcosole::cout << "test";" but it didn't compile.
Where can I find the NetConsole program on the development PC?
(5,084 Views)
Accepted by jnettleton
You simply print like normal.  printf("Hello world\n");  You can view the output in the Net Console Client installed with the utilities update.
(3,125 Views)
I started the "NetConsole for cRIO" program. I entered "10.xx.yy.2" for the machine address and nothing happens. I also tried pressing the Auto button.
Not able to get any output yet. Any ideas?
(3,125 Views)
Make sure you have the firewall off and that you have enabled the NetConsole server in the cRIO imaging tool.
(3,125 Views)
Firewall is turned off (so I can deploy code) and I used the imaging tool to format the cRIO with the NetConsole checkbox enabled.  Is there anything else to enable the NetConsole server?
(3,125 Views)
