01-06-2014 02:50 PM
We are using LVLM with all the updates for FTC and for some reason, when we go to assign buttons to each controller on the "RUN" tab, only one of them can be assigned to a logitech controller, even if 2 are plugged into the laptop. It seems as if either controller 1 or 2 can be assigned, but then the option is "grayed out" on the other drop down menu.
Any suggestions?
01-06-2014 09:17 PM
Have you gone to 'Run Program' and clicked on 'refresh' when both controllers are attached? Then you should see each one operating independently.
When you define buttons using 'Configure Robot Action', just keep an eye on whick controller number is specified.
When you 'prototype' or 'generate code', the 2 controllers should work as defined.
Additional troubleshooting suggestions:
These approaches are what we've found useful when confronted with 'controller problems'
01-07-2014 03:28 PM
Jamodio
Can you post of screenshot? Normally if the controler are connected it will automatically select them for controller 1 & 2.
-Hunter
