Feedback on NI Community
Community Document I added disappeared...
I'm assuming that this is the place to post this issue; apologies if not. One of the documents I posted on 'Community Documents' disappeared. It still exists somewhere, as I can find it at this link (although sometimes that link doesn't work either Smiley Indifferent .) But it no longer appears in the list of documents. The document title was 'LabVIEW BCM2835 Library for Raspberry Pi'. How do I get the document "re-instated"?
(3,312 Views)
Hello Derek,
Thank you for reporting this issue. We'll investigate this further and report back when we have more information.
Best Regards,
Kristi Martinez
NI Community Support
Best Regards,
Kristi Martinez
(3,240 Views)
Accepted by DMurrayIRL
Hi Derek,
I have an update for you. The document was flagged by our automatic spam filter and put in quarantine. The document as been release and can be found in your documents list now. I have also included a post explaining our spam management a little further in the community.
Spam Management in the Community
Help! I made a post and it disappeared from the forums. I made the post again and again, and still it never appeared.
If this happens to you, it is possible that your post was flagged by our automatic spam system and is now in quarantine. If your post is quarantined by the spam system, a moderator will need to approve your post. It will then appear in the community as expected.
Spam is a major issue in many online communities. While it is not ideal that system occasionally has false positives, the spam system we have in place has protected our users from thousands of spam posts since it was implemented. The system learns as we identify what is spam or what is not spam, but there still may be the occasional incident in which a user's post will be quarantined by accident. Posts that may be flagged as spam often contain:
  • Domains or URLs with suspicious syntax
  • Additional or unnecessary HTML
  • Copied and pasted content from other sources or applications (such as Microsoft Word)
There maybe other content that triggers the spam system to flag your post, but in order to prevent spammers from adjusting their posts to not be detected, we can only share the general tips provided above.
If you suspect your post has been caught by the spam system, you can use the Report to Moderator function in the post you were attempting to reply to in order to notify the team of what occurred. You can also post to the Feedback on NI Community board.
Best Regards,
Kristi Martinez
Best Regards,
Kristi Martinez
(3,229 Views)
Yes, I see it in Community Documents now; thanks for the fix. Smiley Happy
(3,224 Views)
