Feedback on NI Community
Mark blogs as read?
If I go to the NI blogs and do a "blog option...mark all as read", they remain bold. Is this correct behavior?
Message 1 of 8
(3,819 Views)
The blog post titles aren't actually bold to indicate read status, that's just how the title is styled. The titles are also larger than what you would see in a board or documents list.
I can see how this may be confusing though. We can investigate if it's possible to have alternate styling for unread/read titles for both blog posts and documents.
Message 2 of 8
(3,814 Views)
Thanks. No it is not a size issue, but the distinction between bold/plain for unread/read is quite universal across the site and should be applied consistently.
So what does marking a blog as read or not read actually do? Seem like a NOOP. 😄
Message 3 of 8
(3,810 Views)
If you're looking at the category page for blogs, you will see there is a new post indicator. Using the "mark as read" option will bring this count to 0.
There's only one blog there right now so there's not much reason to go to that particular page, but with the upcoming migration this will soon change!
Message 4 of 8
(3,808 Views)
The problem I have is when I go into the blog list, I cannot tell which post has updates.  This includes new blog entries and comments.
GCentral
Message 5 of 8
(3,804 Views)
Perhaps instead of the "latest comments" component, we could add an "unread posts" component similar to what you find on a board or in the Idea Exchange. Would that help?
Message 6 of 8
(3,794 Views)
That is what I use with the Idea Exchange.  So, yes, that would help.
GCentral
Message 7 of 8
(3,769 Views)
We'll take a look at possibly adding that. If it helps, there's a way to get to the unread posts link for a blog using this type of URL structure:
http://forums.ni.com/t5/forums/unreadpostspage/board-id/news/tab/message/page/1
http://forums.ni.com/t5/forums/unreadpostspage/board-id/4001/tab/message/page/1
Replace the red text with the ID for the blog, which can be found at the end of the blog page URL:
http://forums.ni.com/t5/NI-Discussion-Forums-News/bg-p/news
http://forums.ni.com/t5/NI-Blog/bd-p/4001
Message 8 of 8
(3,764 Views)
