06-10-2009 03:59 PM
I was looking at the accepted solutions metrics. Can you guess who the top 5 accepted solutions authors are? It's pretty awesome how many solutions these people have authored! I've listed out the totals for the top 5:
1. 233
2. 185
3. 177
4. 124
5. 116
Laura
06-10-2009 04:23 PM
Altenbach, Dennis, Ben, Saverio, MikeS81?
06-10-2009 05:41 PM
06-10-2009 06:30 PM
altenbach wrote:
While my numbers are somewhere in that top 5 range, none of the numbers correspond to what I see in my profile. 😄
The numbers on your profile correspond to every post you've made on every NI board, not just LabVIEW
06-10-2009 06:34 PM
Neither Laura or me mentioned LabVIEW. I think we both talk about the overall number of accepted solution.
(These numbers are not public, so you can only see them for your own profile). 😉
06-11-2009 08:17 AM
And the numbers may be somewhat dated already - I pulled them on Tuesday.
I can confirm that altenbach is in the top 5. Also, tst has 4 out of 5 people listed correctly but the order is a little off.
06-11-2009 10:38 AM
Laura F. wrote:Also, tst has 4 out of 5 people listed correctly but the order is a little off.
I think tst probably meant smercurio_fc instead of Saverio . Same difference. 😄
06-11-2009 10:56 AM
Saverio was one of my forgotten logins. There's also saverio.mercurio, but there's only 16 posts to that one. I couldn't remember the passwords, so I had created smercurio. But then I forgot the password for that one too, and had to create smercurio_fc. The "fc" being the company I used to work for.
That's when I started using a password manager.
06-11-2009 01:00 PM
Yep, I counted smercurio_fc as one of the 4 🙂 So tst has 4 out of 5 correct
06-11-2009 01:47 PM
ok,
then this is my tip:
Altenbach, Dennis, Ben, smercurio_fc, RavensFan
Mike
