09-15-2016 10:44 AM
I have encountered an annoying behaviour of the forums a few times now. It's time to speak out...
The forum often tells me that (for example) the LabVIEW Ideas board has 2 unread posts, but when I go to the LabVIEW Ideas board, it soesn't show me any unread posts...... Looking at the enire list of unread posts for all of the idea exchange boards yields NO results in the LabVIEW ideas board.... I'm assuming these unread posts don't exist?
If they DO exist, wow on earth do I find them? Is it somehow counting posts I have made myself and not registering properly that I've read them (I often read my posts before posting, but not always ).
09-15-2016 10:55 AM
You're not the only one.
09-15-2016 11:28 AM
Ah, thanks for that. Initial search turned up no posts. Now I know I'm not alone.
09-15-2016 02:32 PM
There were some posts moved out of the LabVIEW Idea Exchange, so that is probably what is causing the issue -- similar to what is explained in the topic that Tim linked to. I'll have Lithium take a look.
09-20-2016 03:37 PM
Lithium states that the issue with the Idea Exchange category displaying new post counts that cannot be found should now be fixed. Please let us know if you continue to run into the issue.
