FlexLogger
FLexLogger Problem Loading your Project
FlexLogger displays this dialog message at startup when I select add a new project.  No channel information is available.
(115 Views)
My first troubleshooting step would be to check for missing drivers for your hardware.
Can you correctly see your hardware in NI-MAX? If you use the Test Panels in NI-MAX, do you see valid values on your input channels?
If everything is working in MAX, my next troubleshooting step would be to repair or reinstall your FlexLogger installation using the NI Package Manager software installed on your computer.
(89 Views)
Everything seems to work but FlexLogger.  I connected an M-Series DAQ and no difference.  NI MAX can see the DAQ just fine. I will try a reinstallation.
NI Max to the LEFT - FlexLogger to the RIGHT
(82 Views)
I am back to trying to use the cDAQ and simplifying the system.  Sits at this screen for several minutes.
Then it displays this message.
This is a USB cDAQ-9174 that is one of the most common cDAQ in use. There is no erl.exe process running 😞
(70 Views)
Accepted by topic author MattFitz
Sucess!  Another uninstall and reinstall, several reboots, and FlexLogger is working.  The difference was I downloaded FelxLogger again and this time it prompted me to upgrade NIPM and several packages.
Now works but would of been nice for it to work the first time.
Matt
(64 Views)
