G Web Development Software
Timestamp value on hover
I'm building a graph which consists in having amplitude in Y while Timestamp on X
I'm using a cluster which reciever data from 2 arrays(amplitude  history and timestamp history)
However, when hovering in the graph, the timestamp value converts to a non timestamp value as you can see in the image below.
I wonder if i can see the timestamp hovering the data point..Therefore, i know the exact time the value was aquired.
(1,064 Views)
Hi, i found the library PlotHoverTooltip, and i'm trying to use it, however i've come across an error.
Since my code is a little different, and the graph is displayed by a cluster i dont know if it impacts on the error.
The example attached with the library worked fine, but when i use it in my project i get the follow error:
JavaScriptInvoke in Library::Support::PlotHoverFormat.jsli::Plot Hover Format X AbsTime->Library::XAbsTime GraphTooltip.gvi->WebApp::Páginas::Function.gviweb<APPEND>
An exception occurred within the external JavaScript function called by a JavaScript Library Interface node. Verify your JavaScript code is valid.
function: PlotHoverFormat.XAbsTime, Additional information:
Message: Cannot read property 'querySelector' of undefined
Stack: TypeError: Cannot read property 'querySelector' of undefined
at Object.XAbsTime (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/Library/Support/script.js:9:74)
at e.javaScriptInvoke.jsJavaScriptInvoke (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/VireoImport...)
at u (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/VireoImport...)
at wasm-function[1302]:175
at wasm-function[982]:124
at Object.D.e.eggShell.executeSlicesUntilWait.t.eggShell.executeSlicesUntilWait (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/VireoImport...)
at zo.executeVireoRuntime (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/IdeRun.min....)
at e.vireo.eggShell.setExecuteSlicesWakeUpCallback (http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/IdeRun.min....)
at http://localhost:54907/HtmlVI/Run/VireoDevSystem/Interactive/WebApp/ni-webvi-resource-v0/VireoImport...
(1,003 Views)
Accepted by topic author Labmecepel
Have you define your Graph Control HTML Class Attribute?
And you need to make sure that your Graph has a plot on it. that for, wire the error cluster.
And you don't need to double write to your graph value.
(997 Views)
It worked, thank you!
(980 Views)
Glad to hear that. You're always welcome🙏
Just to let others whom looking for the example source:  Solved: Graph Hover Format for Time Axis. - NI Community
(843 Views)
