G#
error
this class, i create property will occur error.
(4,465 Views)
labview2020 32bit
(4,464 Views)
R-click -> G# -> Create property?
Or drop a Property node in the block diagram?
I can't reproduce it, it seems to work in 2020 SP1.
What's the error you get?
Qestit Systems
Certified-LabVIEW-Developer
(4,427 Views)
Accepted by yanzhanglin
I get an error too. Is this what you get?
The reason is that the attribute name "Lens Parameter" ends with a space, and LabVIEW returns error 7 when trying to save a copy of a file that ends with a space.
Certified LabVIEW Architect
(4,414 Views)
THANK YOU!
(4,401 Views)
