High-Speed Digitizers
Clock source configuration
Sorry, this is completly my  fault... Everything works as it should...
Regards, Valery.
Message 11 of 13
(3,544 Views)
Hi Valery,
Why are you setting the NISCOPE_ATTR_MIN_SAMPLE_RATE attribute?  This will be ignored, or overwritten by the NISCOPE_ATTR_SAMP_CLK_TIMEBASE_RATE attribute.  How are you setting this attribute?  Your error indicates that you are setting this to 12.499750 e12 while the maximum sample rate for your board (5114, I assume) is 250 MS/s.
What do you mean by "When I consistently increse the first one it couses an increase of the second one" when referring to MIN_NUM_POINTS and MIN_SAMPLE_RATE?  These two attributes are independant of each other.
Perhaps if you sent me a section fo your code, I can see what is happening.
Sean Close
Message 12 of 13
(3,542 Views)
Hello Sean,
Don't  worry about it, I have found the mistake which I had done, so there is no reason to familiarize with my code....
Thanks, again.
Regards, Valery.
Message 13 of 13
(3,538 Views)
