High-Speed Digitizers
Determining Sample Rate
Your welcome.  Can you post your new code, because if you have to use niScope Read, you may be back to taking records again.  What didn't work when you implemented it?
Systems Engineer
SISU
Message 31 of 32
(2,797 Views)
Hi Nathan,
Yes my minimum record length and number of samples is 2000 again but it is bound to change because we are having a time varying drive frequency which leads me to believe we have to do some sort of spectral analysis to deal with harmonics as well. I have attached what I have done so far.
Message 32 of 32
(2,786 Views)
