Hi everybody,
I post a new thread because my problem is different than the previous.
On the digitizer 5922, there is an antialiasing filter with a bad step response for my system ! So, i can't use the 5922 card !
See FIR step response.
The system :
-> clk in : 10 Mhz (min : 4 mv / max : 680 mv for 50 Ohms)
-> channel 0 : 0,5 Mhz (min : -6 mv / max : 212 mv for 50 Ohms)
Beginning of the first measure :
You can see the ten first points at the first high level (delta = 20 mv).
The input signal have a 0,5 mhz frequency, so normally, there are no differences on these points (but delta = 20 mv).
I have to take care, antialiasing filter is too slow for my system.
After this problem, i tried to configure this filter : 8 tap hanning have a better step response than others.
Beginning of the second measure :
Finally , i have viewed that i could not having good points before 400 ns (same time in the specification).
My system must have at least 50 ns or 100 ns step response for having some points at about 100, 200 and 300 ns.
What can i do for being faster ?
Bye,
Message Edité par laulaurent le
03-19-2008 12:04 PMMessage Edité par laulaurent le
03-19-2008 12:06 PMMessage Edité par laulaurent le
03-19-2008 12:13 PM
Gendre Laurent
Stagiaire au service Détection à Thalès Alenia Space
E-mail : gendre@polytech.unice.fr
