High-Speed Digitizers
How to use HWS files?
I'm using Soft Front Panel version 2.6 and I obtained HwS files but I can't read them so how could I read them or convert them into notepad file.
Other option are Lvm file but use very short time that's why I want to use hws files.
(6,643 Views)
In the utility section of the NI-SCOPE driver is a link to the HWS file API.  It looks like a folder with waveforms on it.  This will allow you to read the file.  You can convert it  to a text file using the standard LabVIEW file tools.
Alternately, if you are into real pain, you can download the HDF5 toolsets from NCSA and create a C program to do the same, but I wouldn't advise it.  HDF5 has a very steep learning curve and the internal structure of the file is fairly complex.
Let us know if you need more help.
(6,637 Views)
