03-25-2008 06:56 PM
03-26-2008 06:20 PM
Hi Chumak
I understand it won’t be possible to accomplish your proposed system using only one controller. Analyzing the requirements, you need 512 channels and 12-14 bits resolution, so that is 2 bytes per sample. The sample rate should be at least 20 MS/s, so each channel will generate 40 MB/s. If you decide to use the NI 5105, you will have to use a PXI chassis, which has a PCI bus for communication between the chassis and the controller. The maximum data rate in this bus is 132 MB/s, so it translates into approximately 3 channels with your specifications.
Chumak, I see that this is a big system you are asking for and the 5105 is the best option in terms of number of channels, but the bottleneck in this case will be the bus between modules and controller. In terms of data rates I would suggest to look at the PXIe-5122, you will have low density but better data stream rates. However in this solution you won’t be able to use one controller either. The details of the PXI Express systems will depend on the combination of chassis and controller, and you will also have the option to use some PXI modules along with the PXI Express ones. I hope this is helpful,
