High-Speed Digitizers
NI-Scope 2.0 doesn't start
My goal is to work with a NI 5112
I have installed the digitiser in a free PCI-slot: no hardware problems (driver version 2.0.0f0 works fine)
1. I have installed the NI-Scope Software from the NI CD-rom (version 2.0), but Scope-SFP does not start:
error message:
NI-DAQ 6.9.1.f28 OR HIGHER COULD NOT BE FOUND.
YOU NEED TO INSTALL EITHER NI-DAQ 6.9.1,
RELEASED VERSION, OR NI-SCOPE (WHICH INSTALLS NI-DAQ).
NI-SCOPE 2.0 WAS FOUND, BUT COULD NOT BE LOADED.
NI-SCOPE 2.0 MAY NEED TO BE INSTALLED AGAIN.
2. I downloaded and installed the following drivers from the ni.com:
* NIdaq69
* niscope201
But that didn't help
3. In the Measurement & Automation Explorer, I am not able to see the installed NI5112 digitiser
4. Here's the Report, created with the Measurement & Automation:
http://users.ugent.be/~tovthuyn/werk/rapport_for_NI/max_report.htm
How should I proceed with my problem?
20070712
Tom.Vanthuyne@ugent.be
Ghent University
Other:
When opening an example : nicfq32.dll cannot be found
(6,745 Views)
Update:
With following I am now able to launch NI-Scope Front panel, but still the NI5122 is not recognised in MAX:
* uninstalling NI-Scope 2.0.1
* uninstalling NI-DACmx8.5 (that came with LabVIEW 8.2)
* installing NI-DAQ 6.9.0 (not 6.9.1)
* installing NI-Scope 2.0
* placing NI5112 in free PCI slot (+ installing new hardware => OK)
(6,735 Views)
Hi Tom,
You have an older version of the NI-Scope driver. I would uninstall the driver you have and download and install the latest version of NI-Scope (v3.3.1). Once you have upgraded your driver please check to see if the NI-5112 is present in MAX under Traditional NI-DAQ devices, it will not show up under NI-DAQmx devices.
Hope this helps!
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(6,723 Views)
Hi Abhinav,
Thanks a lot for your responsiveness.
After my reply 2 (above), I rebooted my system and then the NI5112 was present in the MAX.
And I am now able to acquire data.
Apparently downgrading the NI-DAQ from 8.5.0f5 to 6.9.1f28 also did the trick.
Other differences between the no good and the good configuration are:
NI-PAL Software: 2.0.0 => 1.4.5f0
NI-SCOPE: 2.0.1 =>2.0
Here's my current MAX-report:
http://users.ugent.be/~tovthuyn/werk/rapport_for_NI/max_report2.htm
But no doubt that your sollution also would have helped. Thanks again!
Tom
(6,712 Views)
