Hobbyist Toolkit
Hobbyist (LV Community 2024 Q3) with Raspberry Pi 3B+ not working anymore?
Hi!
A few years ago I set up an RPi 3B+ with an I2C-potentiometer to control the heating system in my house. I followed this guide: https://learn.ni.com/learn/article/getting-started-with-raspberry-pi-and-labview-community-edition
I have had to reinstall LV Community Edition twice due to license, but when I did it recently (2024 Q3) I could not update LV on the RPi. It "looks" successful but the current version is always empty and it fails to connect when I try to deploy, or connect by right-clicking the RPi in the project view.
So I made a new install on the RPi with the latest RPi OS (64-bit) which was recommended and enabled SSH (and I2C). The problem persists.
Should I use some other OS? I don't remember if I used some special image the first time (years ago)
Here is the log when I do "Update" in the Target Configuration. It seems to think it's a 2B...?
Best Regards, Viktor
Connecting to target...
Successfully connected to target.
Successfully connected. Gathering target info...
Target configuration updated.
OS Version: 12.7
CPU: Raspberry Pi 3 Model B Plus Rev 1.3
Systemd Version:
Has Internet Access: True
Device Type: Raspberry Pi 2 B
OS Version: 12.7
Systemd Version:
blacklist spi-bcm2708is not present.dtparam=spi=on already exists.i2c-dev already exists.i2c-bcm2708 already exists.blacklist i2c-bcm2708is not present.dtparam=i2c1=on already exists.dtparam=i2c_arm=on already exists.
Adding MakerHub feed...
deb [trusted=yes] http://feeds.labviewmakerhub.com/debian/ binary/
Updating package index. This may take over 30 seconds depending on your internet speed...
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Ign:5 http://feeds.labviewmakerhub.com/debian binary/ InRelease
Ign:6 http://feeds.labviewmakerhub.com/debian binary/ Release
Ign:7 http://feeds.labviewmakerhub.com/debian binary/ Packages
Ign:8 http://feeds.labviewmakerhub.com/debian binary/ Translation-en
Ign:9 http://feeds.labviewmakerhub.com/debian binary/ Translation-en_GB
Hit:7 http://feeds.labviewmakerhub.com/debian binary/ Packages
Reading package lists...
Installing LabVIEW...
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
avahi-utils blt bluez chromium-browser chromium-browser-l10n
chromium-codecs-ffmpeg-extra cups-pk-helper device-tree-compiler
distro-info-data docutils-common dos2unix edid-decode flashrom fonts-piboto
gir1.2-gmenu-3.0 gir1.2-handy-1 gir1.2-notify-0.7 gir1.2-packagekitglib-1.0
gir1.2-polkit-1.0 gir1.2-secret-1 gnome-menus grim gtk-nop
gtk2-engines-pixbuf gtk2-engines-pixflat gui-pkinst gui-updater hplip-data
i2c-tools ibverbs-providers iw javascript-common keyutils libaio1 libaml0
libatkmm-1.6-1v5 libboost-iostreams1.74.0 libcairomm-1.0-1v5 libcupsimage2
libdaxctl1 libdbusmenu-glib4 libdbusmenu-gtk3-4 libegl-dev libexpat1-dev
libfdt1 libgfapi0 libgfrpc0 libgfxdr0 libgl-dev libgl1-mesa-dev libgles-dev
libglibmm-2.4-1v5 libglu1-mesa libglu1-mesa-dev libglusterfs0 libglut-dev
libglut3.12 libglvnd-core-dev libglvnd-dev libglx-dev libgnome-menu-3-0
libgtkmm-3.0-1v5 libhpmud0 libi2c0 libibverbs1 libice-dev libimagequant0
libjs-jquery libjs-sphinxdoc libjs-underscore liblgpio1 libliftoff-rpi
libnbd0 libndctl6 libneatvnc0 libnfsidmap1 libnma-common libnma0
libopengl-dev libopengl0 libopusfile0 libpangomm-1.4-1v5 libpmem1
libpmemblk1 libportmidi0 libpthread-stubs0-dev libpython3-dev
libpython3-stdlib libpython3.11-dev libqt5designer5 libqt5help5
libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5xml5
librados2 libraqm0 librbd1 librdmacm1 librtimulib-dev librtimulib-utils
librtimulib7 libsane-hpaio libsdl2-image-2.0-0 libsdl2-mixer-2.0-0
libsdl2-ttf-2.0-0 libsigc++-2.0-0v5 libsm-dev libtcl8.6 libtk8.6
libturbojpeg0 libwf-config1 libwf-utils0 libwlroots11 libx11-dev libxau-dev
libxcb1-dev libxdmcp-dev libxext-dev libxt-dev lp-connection-editor
lxde-common lxplug-bluetooth lxplug-ejecter lxplug-magnifier lxplug-menu
lxplug-netman lxplug-volumepulse mate-polkit-bin pi-greeter
pi-printer-support pishutdown pixflat-icons pixflat-theme
printer-driver-escpr printer-driver-hpcups printer-driver-postscript-hp
pulseaudio-module-bluetooth python-apt-common python-babel-localedata
python3-asgiref python3-asttokens python3-babel python3-blinker python3-bs4
python3-click python3-colorama python3-debconf python3-dill python3-docutils
python3-dotenv python3-html5lib python3-isort python3-itsdangerous
python3-jedi python3-jwt python3-libevdev python3-logilab-common
python3-mccabe python3-mypy-extensions python3-olefile python3-opengl
python3-parso python3-pexpect python3-pip-whl python3-platformdirs
python3-ptyprocess python3-pygments python3-pyinotify python3-pyudev
python3-responses python3-roman python3-send2trash python3-setuptools-whl
python3-soupsieve python3-toml python3-tomlkit python3-typeshed python3-tz
python3-v4l2 python3-webencodings qt5-gtk2-platformtheme
qt5-style-plugin-cleanlooks qt5-style-plugin-motif
qt5-style-plugin-plastique qt5-style-plugins qt5ct raspi-utils-core
raspi-utils-dt raspi-utils-eeprom raspi-utils-otp read-edid rp-bookshelf
rpcbind rpd-wallpaper rpi.gpio-common scrot tk8.6-blt2.5 triggerhappy
wayfire wlr-randr x11proto-dev xorg-sgml-doctools xsel xsettingsd xtrans-dev
zlib1g-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
gcc-12-base:armhf krb5-locales libatomic1:armhf libaudit1:armhf
libboost-filesystem1.74.0:armhf libboost-iostreams1.74.0:armhf
libboost-program-options1.74.0:armhf libbz2-1.0:armhf libc6:armhf
libcap-ng0:armhf libcom-err2:armhf libcrypt1:armhf libdb5.3:armhf
libexpat1:armhf libffi8:armhf libgcc-s1:armhf libgpm2:armhf
libgssapi-krb5-2:armhf libidn2-0:armhf libk5crypto3:armhf libkeyutils1:armhf
libkrb5-3:armhf libkrb5support0:armhf liblzma5:armhf libncursesw6:armhf
libnsl2:armhf libpam0g:armhf libpython3-stdlib:armhf
libpython3.11-minimal:armhf libpython3.11-stdlib:armhf libreadline8:armhf
libsqlite3-0:armhf libssl3:armhf libstdc++6:armhf libtinfo6:armhf
libtirpc3:armhf libunistring2:armhf libuuid1:armhf libzstd1:armhf
python3:armhf python3-importlib-resources python3-minimal:armhf
python3.11:armhf python3.11-minimal:armhf schroot:armhf schroot-common
uuid-runtime zlib1g:armhf
Suggested packages:
glibc-doc:armhf locales:armhf libnss-nis:armhf libnss-nisplus:armhf
gpm:armhf krb5-doc:armhf krb5-user:armhf libpam-doc:armhf python3-doc:armhf
python3-tk:armhf python3-venv:armhf python3.11-venv:armhf
python3.11-doc:armhf binutils:armhf binfmt-support:armhf aufs-tools:armhf
| unionfs-fuse:armhf btrfs-progs:armhf debootstrap:armhf lvm2:armhf
qemu-user-static:armhf zfsutils-linux:armhf
The following packages will be REMOVED:
agnostics alacarte apt-listchanges arandr cifs-utils fio gldriver-test hplip
libinput-tools lxde lxde-core lxplug-cputemp lxplug-network lxplug-ptbatt
lxplug-updater mypy nfs-common openbox openbox-lxde-session pastebinit
pi-bluetooth pi-language-support pipanel piwiz pylint python-is-python3
python3 python3-apt python3-astroid python3-av python3-cairo
python3-cffi-backend python3-cryptography python3-cups python3-cupshelpers
python3-dbus python3-dev python3-flask python3-gi python3-gi-cairo
python3-jinja2 python3-kms++ python3-lazy-object-proxy python3-lgpio
python3-libcamera python3-libgpiod python3-lxml python3-markupsafe
python3-minimal python3-mypy python3-numpy python3-oauthlib python3-openssl
python3-pgzero python3-picamera2 python3-pidng python3-piexif python3-pil
python3-prctl python3-psutil python3-pycryptodome python3-pygame
python3-pyqt5 python3-pyqt5.sip python3-renderpm python3-reportlab
python3-reportlab-accel python3-requests-oauthlib python3-rpi.gpio
python3-rtimulib python3-sense-hat python3-simplejpeg python3-simplejson
python3-smbc python3-smbus python3-spidev python3-tk python3-twython
python3-venv python3-werkzeug python3-wrapt python3.11 python3.11-dev
python3.11-minimal python3.11-venv raspberrypi-net-mods raspberrypi-sys-mods
raspberrypi-ui-mods raspi-config raspi-utils raspinfo rc-gui rp-prefapps
rpd-plym-splash rpi-eeprom sense-hat system-config-printer
system-config-printer-common system-config-printer-udev thonny userconf-pi
wayvnc wf-panel-pi
The following NEW packages will be installed:
lvrt24-schroot:armhf python3:armhf python3-importlib-resources
python3-minimal:armhf python3.11:armhf python3.11-minimal:armhf
schroot:armhf schroot-common uuid-runtime zlib1g:armhf
0 upgraded, 49 newly installed, 103 to remove and 0 not upgraded.
Need to get 17.9 MB/34.8 MB of archives.
After this operation, 237 MB disk space will be freed.
Get:1 http://deb.debian.org/debian bookworm/main arm64 python3-importlib-resources all 5.1.2-2 [19.0 kB]
Get:2 http://feeds.labviewmakerhub.com/debian binary/ lvrt24-schroot 24.1.0-3 [17.8 MB]
Fetched 17.9 MB in 14s (1,254 kB/s)
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
Ignoring Error: 56 NI_Subprocess.lvlib:Raw Subprocess.lvclass:_Select.vi:4540001<APPEND>
<b>Complete call chain:</b>
NI_Subprocess.lvlib:Raw Subprocess.lvclass:Interact.vi:2440001
NI_Subprocess.lvlib:Buffered Subprocess.lvclass:Pump.vi:6140001
NI_SSH.lvlib:Execute SSH Command.vi
LMH-LINX.lvlib:SSH Execute Command.vi
LMH-LINX.lvlib:Install LV Support.vi
LMH-LINX.lvlib:Target Configuration.vi
Rebooting Target...
Checking target status...
Installation completed successfully. Click Launch Example to get started.
LMH-LINX.lvlib:SSH Async Execute Command.vi
LMH-LINX.lvlib:Reboot Target.vi
OS Version: 12.7
CPU:
Systemd Version:
Device Type: Unknown
(1,028 Views)
Accepted by topic author ctm5556
Nevermind. Found that many people has this issue.
Installed LV Community 2022 Q3 and used a pre-installed RPi image - 2022 (22.3) - from here: https://github.com/LVMakerHub/LINX/wiki/Installing-an-image-with-LabVIEW-pre-installed
Works perfectly!
(1,018 Views)
