[IDLE] Indianapolis User Group
Hi... im doing my Mtech, my project is design and development of automated test jig to test current transformers, please can ull give suggestions how to proceed regarding it.....
Hi..My project is development and design of automated test jig to test instrument current transformers.. please can ull suggest how can i proceed how help ful it is using ni instruments and labview
(6,700 Views)
What's an "Mtech"?  "ull"?
Step #1 Search Google: "current transformer tester", and read associated articles
http://www.kilowattclassroom.com/Archive/CTTesting.pdf
http://ezinearticles.com/?Testing-a-Transformer--How-To-Accurately-Test-A-Transformer&id=56803
Step #2 Decide what tests that you want to perform and if there are "real-time" (synchronous) requirements.
               Write a requirements document.
Step #3 Sketch your system and define your I/O, decide how automated the system will be,
              (manually fed, or automatically fed from a bin or robotic loader).  Write a bill of materials document.
Step #4 Design your user interface and then
               simulate your system in software by writing the data acquisition software (.i.e. Labview)
               to see if you need to make changes to the requirements or bill of materials.
Step #5 Procure your data acquistion and associated testing hardware, power supply, load, etc
Step #6 Update the software to use the real hardware, then check everything out.
(5,752 Views)
