07-23-2024 01:42 PM
I've deployed a system using an NI 9467 GPS card to ensure data is acquired at top-of-second according to GPS using the Pulse per second (PPS) functionality. My client has asked how the timing system behaves when GPS is not available. My testing indicates that the NI 9467 continues to track time (and produce regular PPS signals) even if it loses GPS connection, but I've had difficulty find documentation describing its behaviour.
Can we confirm PPS signals are still reliable after a GPS signal is lost?
How long will the NI 9467 run with accurate PPS signals in the absence of GPS?
Where can I find documentation that describes the behaviour of NI 9467 when GPS is lost?
07-31-2024 08:42 AM
I worked with NI support and have the following updates to the questions in bold:
