Industrial Communications
EtherCAT Master in Ethernet Apdapter eth0 (Primary)
Hi
I am trying to communicate from NI-9063 to an panasonic servo drive using EtherCAT communication. We got into a problem were the primary port is not able to convert into a EtherCAT Master. Is there any way to change the Primary Ethernet port (eth0) to a EtherCAT Master.
(1,696 Views)
Have you install NI-EtherCAT driver on the cRIO-9063?
See step 6 in Setting Up EtherCAT on NI Programmable Controllers
Control Lead | Intelline Inc
(1,668 Views)
Thanks for the replay,
Yes I have installed Industrial Communication for EtherCAT, NI inherantly won't let us use the primary ethernet port for EtherCAT communication. But I am looking for some kind of command line method to make the primary ethernet also to EtherCAT.
(1,641 Views)
