09-15-2017 06:45 AM
Is it possible to use the PXI-8513 with the CANopen software from NI?
Or do I need different hardware from from NI?
09-15-2017 07:35 AM
The documentation states that MOST of these X-NET interfaces are backwards compatible with CAN programs. Not sure which ones are not compatible.
09-17-2017 09:22 PM - last edited on 01-11-2024 03:46 PM by migration-bot
You can use NI CANopen hardware (NI 9881, PXI-8531, PCI-8531) to implement the CANopen application. And the NI-Industrial Communications for CANopen 17.0 is necessary.
Thanks!
09-17-2017 11:58 PM
That's really disappointing.
I thought I saw something about canopen for this card.
I will write the canopen layer myself then.
09-18-2017 08:02 AM
Technically there still is another way. You could use something called CANopen for LabVIEW Library. It is not officially supported anymore but you can still buy it from your NI Sales person. (P/N 779684-01) It is around $100 and works with the old NI-CAN driver and the Compatibility layer for NI-XNET for your board.
-DirkW-
09-20-2017 04:29 AM
Thank you all for the information but I think I will write the canopen function myself.
I will need to write SDO packets which do not look difficult to make.
Greets,
Bart
08-31-2018 11:37 AM
Have you been able to get PXI-8513 established CANopen ? I'm trying to control multiple Maxon EPOS4 using CANopen?
09-03-2018 01:00 AM - edited 09-03-2018 01:03 AM
We purchased the IXXAT canopen device.
As far as I can see it works good.
Still it would be great if NI would release a canopen driver for a generic CAN device.
When you want to use canopen, you allways have to get a PXI card, sadly there is no USB to CANopen from NI.
