Andor luca is not shown in interface of NI-MAX
Good morning guys,
I have the following problem:
The camera is not displayed in the NI interface.
It's available:
- Andor Luca (recognized by PC, the camera is compatible with Labview) connected with USB Port
- Andor Solis Aquisition Software (after the installation I copied the SIFReaderSDK with LabViewSIFReaderVI into the folder Labview)
-Labview (with the Vision Aquisition Software)
Do I need anthor program of LabView?
greetings
(3,861 Views)
Hi Band,
did the NI NI-IMAQdx driver get installed along with the Vision Acquisition Software? You can see that in the Software Section of your Measurement and Automation Explorer...
Did you have a look at this document:
Getting Started with USB3 Vision Cameras and NI Vision Acquisition Software - National Instruments
http://www.ni.com/tutorial/14423/en/
Niko NR
Systems Engineer, National Instruments
(3,828 Views)
Hi NikoNR,
yes I have the NI-IMAQdx driver. First I had the VAS Version 2009 , there the folder NI-IMAQdx was shown. But when I updated to the Version 2016, not more. But now I have the the webCam there, which was shown in the Folder NI-IMAQdx, when I had the Version 2009.
No, I didn't have a look on this document, because i don't have USB 3.0 on my Laptop.
regards
(3,824 Views)
Hi Band,
I had a look a bit more deeply into the question but didn't get anywhere. Could you upload you MAX Report? Parhaps I find something that is missing...
Using MAX Technical Report to Document Measurement & Automation Explorer (MAX) Configuration Information - National Instruments
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
cheers,
Niko
Niko NR
(3,799 Views)
okay, I will show you.
regards
Band
(3,787 Views)
