09-19-2014 06:19 PM
@leaven wrote:
Hi PokeChop
I want to use Labview to control an Omron programmable relay (ZEN-V2 series) which was communication with compoway/f protocol.
But I can't find more information about compoway/f protocol.
And in this forums, I find you have controled a Omron device by compoway/f protocol.
Can you give me some information about compoway/f protocol.
This actually looks fairly straight forward
Have a good ASCII chart handy
it does look like the "BCC" example is a failure of the tech writer- try a simple sum array rather than XORing.
09-19-2014 09:22 PM
Hi Poke
Can you share the VI with me? Thanks.
09-19-2014 09:48 PM
thanks for your help
09-23-2014 03:01 PM - edited 09-23-2014 03:03 PM
I'm having trouble attaching the vi to this reply.
I keep getting:
"The contents of the attachment doesn't match its file type."
Is there another way to attach a vi to the forum posts?
Can you tell me what your email is and I can send it to you?
09-23-2014 03:14 PM
09-23-2014 03:19 PM
Ok, Thanks for the info on the attachment.
The vi was created in the usual deadline crisis mode, so please do not
be too criticl of the code!
Hope it works for you.
10-01-2014 07:54 AM
Any chances you would have a part of VI you would be willing to share? I am using an OMRON ZS-LD40C, and getting started is already a struggle,
Many thanks,
Kentmey
10-01-2014 09:06 AM
Here is what I have:
Good luck.
10-01-2014 10:15 AM
Hey,
that was quick, thanks
Could you save them with labview 2011 because I don't have labview 2013?
Many thanks,
Kentmey
12-14-2016 06:45 PM
Thank you for excellent programs!
However, I can' t find 485 TEST.VI.
Could you attach the VI?
