03-01-2022 05:00 AM
Hi
All info is hidden in the dll that has a strange opening in the initialize.vi
In fact 3 operations are happening at the same time (not connected by wires in sequence
1) the dll opens the serial port
2) the settings of the serial port are modified in visa properties in the middle
3) the port wil be opend by visa and asked for Idn*
These should not be happening at the same time anyway.
I can try to work out a complete vsa example instaed of this example.
Should be ready late this evening.
03-01-2022 05:02 AM
03-03-2022 09:32 AM
Hello ,
the problem is solved with my multimeter, i did not use VISA to communicate with , i just used some blocks of code from the sub VI of the driver provided on the web site of "Metrix", but be careful , using direct Sub Vi only can not work , case "voltage" sub VI show me in error, i attach a screenshot of my code and programm
Thank you for all for the time devoted to this problem
