GPIB-RS232 converter issues
Hi, I am having trouble communicating to the NI GPIB-RS232 converter box - http://www.ni.com/en-us/support/model.gpib-rs232.html
I can connect and configure the converter when in Config mode using the NI GPIB-Serial Converter Wizard.  When I test in both MAX and LabView, I get a good response when sending a *IDN?\n to the box (attached screenshot).  The problem comes when using the same settings when the converter is changed to Normal mode - I get no response from the box with the same connection using the same programs (MAX/LabView).
My current setup is simply using a USB-RS232 dongle to connect to the serial port on the converter box.  This will control an instrument over GPIB.
Ultimately I want to use the RS232 port on my CompactRIO chassis (9064) to do this (yes, I'm aware GPIB is not real-time and generally not recommended for embedded use, I'm OK with that).  But that's down the road, I want to talk to the converter first directly.
Thanks in advance,
Don
(4,322 Views)
Hi drmase13,
What do you mean when you put it in normal mode? This device can get into 4 different modes and each of them has its own specifications. Take a look at the device's Help here http://digital.ni.com/manuals.nsf/websearch/99625A6E8B9F625A862571C0004DDE84
By the way, here you have an example using this device on a cRIO http://www.ni.com/example/30978/en/
PedroR
(4,226 Views)
Thanks for the reply.
The converter has a switch on the back to set it to Config mode or Normal mode, that's what I'm referring to.  Config mode works OK and I'm setting it to S mode while configuring it.
But with the switch at Normal, I can't get any response.  I am using a small section of the example you linked - http://www.ni.com/example/30978/en/
My test VI is only a subsection of the Init Convbox.vi from that example.  I'm not able to get any identification response.
(4,213 Views)
drmase13
I think you get a reply when it's in config mode because the computer sees the converter as the "target" for the query but when you put it in normal mode, it's just a "cable"
Do you have a GPIB device you can connect and try the query?
PedroR
(4,197 Views)
