GPIB-USB-HS no light on Ready and Active
i have a GPIB-USB-HS and it works well before, i found it doesn't work well yesterday and their is no light on Ready and Active, could you help to check what's the possible reason?
thanks
Yang LI
(1,219 Views)
Could you solve the problem. Because I have exactly the same problem and I could not solve it. If yes, how did you do? Thanks in advance 😊.
(1,078 Views)
