06-22-2016 07:28 PM
New to the linux life. Done this many times in Windows.
Using CentOS 7 in a VM on a MacBook Pro. Also installed are VMs for OSX and Windows 7.
I want to use PyVISA to control instruments via GPIB, so I need NI-VISA installed. I downloaded the iso image for NI-VISA-15.5.0 and got it installed, at least it finished without error.
When I plug in the GPIB-USB-HS to the USB port, I get a message from the VM manager, asking which VM I want to connect it to. If I select "Windows 7 64-bit", it enumerates and shows up as a device just fine, as it should.
If I choose "CentOS 64-bit", I get nothing. When I run ResourceManager under PyVISA, I see 4 ASRL instruments, but no GPIB. If I connect the GPIB-USB-HS to an instrument, the instrument does not appear.
If I look in /dev, I see no GPIB device. I *do* see nipalk.
I tried installing NI-488.2, but it refused to do anything becuase a newer or current version was already installed, I assume when I installed VISA. Is that the case?
I don't know what tests to do next to diagnose or give more info to the problem. Thanks for any advice.
Ed K
06-23-2016 02:21 PM
found it - 32-bit support is not installed on my computer. Why does the installer not catch this?
06-23-2016 02:27 PM - edited 06-23-2016 02:29 PM
Hi Ed,
What are you using to communicate with/run the VM? You may need to look into how that program handles communicating with hardware. Generally, if there's an easier way to do what you're trying to do, I would recommend that path instead.
To my knowledge, 488.2 should not conflict with VISA.
Edit: Ah, it looks like you got it.
08-10-2016 02:29 AM
I just started to work with NI products in Linux.
I have the same problem: I installed NIVISA-15.5 and NI488.2-3.2 on CentOS7 (64bit, Kernel 3.10) and GPIB-USB-HS doesn't mount! I want to use it for pyVISA.
My question according to the posts above: Which 32bit packages are necessary to make it works?
08-11-2016 10:01 AM
Jerry,
From Ed's experience, it looks like you need 32-bit support to be installed. I'm not sure in which installation that would be installed, but can you try repairing the installation of NI-VISA and NI-488.2 to make sure that 32-bit support is installed?
08-12-2016 09:51 AM
Unfortunately, NI-488.2 for Linux version 3.2, won’t work for 2 reasons:
NI-488.2 hasn’t supported USB starting with 3.2. Earlier versions of GPIB won’t be able to install on newer Linux distros as there is a tight matching between our driver and the Linux kernel it was built for at the time the driver was released.
08-12-2016 10:51 AM
One option if you are using this on a Linux VM on a Windows or Mac host is to enable NI-VISA Server on the host. The Linux VM could then use NI-VISA to talk to the GPIB-USB-HS over the network.
What NI-VISA Features are Supported on my Operating System?
Unfortunately there is not going to be any way to use NI-488.2 with a USB GPIB adapter on CentOS 7. There is an open source driver available from a third party that provides a similar interface, but it may not be 100% compatible with your application. There may also be licensing concerns for your use-case, and I don't know whether it works with PyVISA.
Third-Party Linux GPIB Package
Finally, there is the option of switching to a different interface for use on CentOS 7. PCI-GPIB and PCIe-GPIB interfaces are fully supported if this is a desktop system, although they won't be usable if this is a VM. The GPIB-ENET/1000 could be used from any CentOS 7 system.
