GPIB communication time
I want to confirm the overhead ni gpib communications time.
Once Host PC with NI GPIB participate with Tester & handler communication, the test time increase almost 190 milliseconds.
Consider NI GPIB took overhead 190 milliseconds more.
Anyway to reduce this time ?
(2,680 Views)
Depends.  190ms isn't a long time.  What are you doing?  Let's see some code and perhaps we can show you more effecient ways to do things.
You should initialize communications, trigger the measurement, buffer the data on the instrument, then read the data back once the measurement is complete.  If you want to run really fast measurements, avoid reading data to PC while measuring.  Generally instruments are very fast at gathering data, but transferring the data to the PC takes time (maybe 10-20ms/data point depending on the instrument).  So you should buffer all the data on teh instrument (to instrument internal memory) then read that data once at the end.  The read can take many seconds but you avoid delays in the measurement.
Craig
(2,631 Views)
Thanks for your reply.
Instrument A and Instrument B communicating through Gpib.
Another computer (C) connected with NI gpib to read message for some reports.
our program connect and use ibrd function  on C and read continuously char by char.
once C connected instrument time increase by 190 ms.
Now we notice that we use NI GPIB USB HS . is it possible to decrease this overhead time if we use PCI card ?
(2,626 Views)
Latency and overhead for PCI is about the same as USB.  Why read char by char?  It seems like your instruments are really slow, and all the communication is slowing you down.  But without knowing details - instrument models and code, there's not much more to suggest.
(2,610 Views)
Accepted by topic author GovinR
Latency and overhead for PCI is about the same as USB  = Not true
we just tested and found the cause.
USB HS  : overhead time 190 MS
PCI : overhead time 35 MS almost 6 times lesser.
Thanks for your advice.
(2,590 Views)
Wow, you spent over 7 years to do this one test!  That seems excessive when you could have just used this: Instrument Bus Performance.
You just hit a pet peeve of mine:  Capitalization matters.  You wrote 190 MegaSeconds, which comes out to be over 6 years.  Many would actually interpret your statement as MegaSamples, which really makes no sense in respect to time.  You really meant to write 190ms (190 milliseconds) and 35ms.
GCentral
(2,571 Views)
Hmm.  Is that a significant amount of time?  Not usually, but I can't tell what you tested.    Also lot of that time difference is probably going to depend on your PC motherboard and how it supports PCI vs USB. You should structure your code so that minuscule difference does not cause any issues down the road in case you upgrade other things.
To assist people in the future who searc the forums, you could give details of how you tested each setup, any code used in the testing, and your PC/OS setup.  Those details may be a lot more relevant in the future than the times posted and might be of use to someone who was in your situation.
Craig
(2,515 Views)
