GPIB instrument legacy Microlink 4000 using GPIB-USB-HS
Accepted by topic author JBYChan
No, those are not commands when you are using the obj library. They are basically the same thing as function calls to a dll. The actual commands are hidden in the obj. You would need it's source code.
Message 11 of 12
(2,019 Views)
I'm still very stuck on how to even send commands over to these instruments via GPIB-USB-HS. I've been using MAX to attempt to communicate by the VISA testing panel and Interactive Control.
I'm unsure of what to do at the moment, can you please lend me a hand?
Please find attached the Programming Manual.
Message 12 of 12
(1,966 Views)
