GPIB with labVIEW
If anyone can help me out, I am trying to hook up a Keithley 3390 Arbitrary Waveform Generator to LabVIEW with GPIB to control the generator.  The waveform generator is hooked up with an oscilloscope with a BNC cable and I want to use the instrument drivers for Keithley 3390.  I am new with LabVIEW and I thought I did everything right but it keeps giving me this error message saying id query failed.  I have found on multiple sites to disable the id query all together.  Does anyone have any input?
Message 1 of 20
(5,618 Views)
Which driver are you using?  Can you show us your code?
GCentral
Message 2 of 20
(5,615 Views)
Im using Keithley 3390 Standard Waveform.vi Driver and it's with labVIEW 2013
Message 3 of 20
(5,599 Views)
That is the actual name of the instrument driver in labVIEW
Message 4 of 20
(5,595 Views)
ID query is being done in the initialze VI. Look for it.
Message 5 of 20
(5,552 Views)
I found the id query and the initilize VI controls.  There is an option that says turn the id query to false but I don't believe that it is disabling it.  I tried that but then it still gives an error message.  I will take screen shots tomarrow when I am in the lab so it is more clear.  Also sorry I posted two posts it was just really frustrating me.
Message 6 of 20
(5,493 Views)
I took screenshots of the error message, the initilization front panel, and the block diagram.  I am not sure what to do next though
Message 7 of 20
(5,439 Views)
also of the instrument that I am using
Message 8 of 20
(5,437 Views)
You still have the ID Query turned on.  Wire up a FALSE to that input and see what happens.
GCentral
Message 9 of 20
(5,426 Views)
I tried that already and got another error code
Message 10 of 20
(5,398 Views)
