Getting the measured multiple values from multiple channels of Agilent DSO-X 2014A 4-ch oscilloscope
           Hi, all
I'm Sean Ahn, using LabVIEW 2013 sp1 with Agilent DSO-X 2014A  4-ch oscilloscope.
As attached vi file, I’m trying to get the measured multiple values from multiple channels of Agilent DSO-X 2014A  4-ch oscilloscope. But every time I try ‘Read Measurement : Statics’ I get the error message ‘hardware missing’ from oscilloscope, while ‘Read Measurement : Continues’ setting gives no problem working very well (but, it gives only one measured value-the last one in the list.).
In the user’s guide from Agilent, the error message is described as below.
-241, Hardware missing
This message can occur when a feature is unavailable or unlicensed.For example, some serial bus decode commands are only available when the serial decode options are licensed.
I already tried both USB and ethernet connection between PC and oscilloscope to get the same result. 😞
How can I solve this problem? Or is there any other way to get multiple values from multiple channels using ‘Read Measurement : Continues’?
Thanks in advance
Sean Ahn
(4,994 Views)
Accepted by SeanAhn
That error is telling you that you need to purchase an option to get that functionality.
GCentral
(4,985 Views)
Accepted by SeanAhn
The word unlicensed should have been a clue.
(4,978 Views)
