06-07-2016 07:22 AM
I can't find any HOST PC COM port on my cRIO.
I tried to use global variable but it was unuseful. Is there any solution?
Solved! Go to Solution.
06-07-2016 10:58 AM
@sad0000 wrote:I can't find any HOST PC COM port on my cRIO.
And why should it? A cRIO is really another computer. Would you expect your PC to see the serial ports of another PC on your network? No, you wouldn't.
If you really want the cRIO to do communications of some sort over the serial port of the PC, then you will need to make an application on the PC that can communicate with the cRIO, typically over TCP/IP or Network Streams.
06-07-2016 10:23 PM
crossrulz 已寫:And why should it? A cRIO is really another computer. Would you expect your PC to see the serial ports of another PC on your network? No, you wouldn't.
thank you for your reply. I will try your solutions.
Here is my project. Detect one direction force value and control a motor. I chose scan mode to detect my sensor. I must put the program under cRIO to make sure the value is correct. If the program is under cRIO, it cannot connect my PC port so that I cannot send any request to my control board
I tried VISA server but it cannot work
06-13-2016 05:11 AM
@crossrulz wrote:And why should it? A cRIO is really another computer. Would you expect your PC to see the serial ports of another PC on your network? No, you wouldn't.
thanks bro!
I tried TCP/IP. This way solves my problem.
