08-12-2010 04:33 AM
I understand how to make one controller work from LV, but I don't understand how to make two of them work. They both work when using SMC100 User Tool, but I was unable to find the "addressable controllers". So the question is, how to address not the first but the second controller connected serially?
08-12-2010 05:12 AM
Looks like I've already found an answer to that question 🙂 One should address different axes numbers for the "Axis in" parameter. Each exis corresponds to an individual device.
08-16-2010 10:30 PM
I am having the same problem. My controllers work perfectly in the Newport software, but not in Labview. Your solution seems obvious to me, but it still has not enabled me to communicate with the two daisy-chained controllers. I assume part of the problem is that the 1st is connected RS232, while the other is RS485 and that maybe the Port Initialization VI is supposed to produce a different kind of VISA session ID other than ASRL1::INSTR and ASRL3::INSTR. I believe there is at least some communication between the devices, since the controller addresses were configured to 1 & 3 using the utility software and I get an error if I incorrectly input 2, or something else, as a port number in Labview. If I query the controllers' parameter settings in Labview, I get back absolutely nothing...not even an error. I tried the SET/GET Controller's Axis number VIs, which is supposed to allow the user to assign/query the RS-485 address for the controller configured for RS232. I attempted to set axis 1 to controller axis 2, then get the controller axis to confirm the setting, but the query just returned 0.
If anyone has any suggestions that would be great!
Bianca
08-17-2010 01:54 AM
05-06-2012 10:08 PM
Hi guys can you show the VI here or explain how to make 2 controller work? Please help!!!
05-07-2012 12:25 AM
05-07-2012 12:29 AM - edited 05-07-2012 12:35 AM
I am cracking my brain on how to address the 2 controller using labview. Using Nstruct I had address it but not sure how to do it with labview. Can you guide me to do it?
05-07-2012 01:58 AM
05-07-2012 02:03 AM
Sorry but I really confuse what is the axis and what is the visa, my problem is I am able to control the first motor controller but don't know how to control the second motor.
05-07-2012 05:53 AM
