12-11-2018 09:30 AM - edited 12-11-2018 09:31 AM
our NI PXIe-1078 chassis houses a PXIe-6363 I/O card which has hardware timing capabilities as far as I know. Is it possible to communicate from this card to an I2C or SPI device directly from the chassis instead of using FPGA? The PXIe-6363 features multiple digital I/O ports and there is the palette:
"Connectivity"=>"I2C&SPI" which contains the I2C Configure.vi and the SPI Configure.vi. However both require FPGA functionality.
Thanks in advance
Lysandros
Solved! Go to Solution.
12-12-2018 04:35 AM
Hello Lysandros,
unfortunately you will need an FPGA Device or an dedicaded I2C or SPI Device.
Best wishes
