08-21-2014 02:20 AM
Hello everyone,
I have limited knowledge about labview and have been trying to learn labview through online help and youtube videoes. Now my professor requires me to make a VI that will measure current-voltage (IV Characteristic of a transistor) using Keithley 6487 picoammeter. Unfortunately I have been unable to find any good help/assistance regarding this.
My questions are:
1. How will I go about making this program?? (Honestly I have no idea)
2. I have to communicate with instrument through GPIB. I don't know how to program this?
It seems like i am asking you guys to make VI for me but that is not the case I just need proper direction where I can consult and learn while making the program. Any help will be greatly appreciated.
08-21-2014 03:55 AM
Hi HamzaZG,
good start is to visit Keithley webpage , install Keithley IO Layer and drivers . After that you will see a palette in LV and you can try to use LV example from keithley webpage.
CaravagGIO
08-21-2014 04:12 AM
Don't follow the advice to install the keithley IO-layers.
It will add a lot of software and you get more lost than just staying within LabVIEW
Added is a small begin for a LabVIEW based instrumentdriver for the 6485 but this should be compatible....with the 6487.
Furthermore starting to develop a big program in LabVIEW without starting small is very difficult. As is all programming in a new environment.
NI makes you beleive it is easy, and that is true, but only for small programs.
So start small and learn how to go on by growing.
08-25-2014 07:55 AM
Guys thank you for providing the link for KE6485/6487 IO layers ..
I know making such a big problem will not be a easy task by any means but I have to do it.
Thanks again ..
Does anyone have/ know link to a detailed tutorial for interfacing/programming equipment through labview??
I have not been able to find anything that provides much detail
08-25-2014 10:19 PM
08-25-2014 10:34 PM
08-26-2014 12:04 AM
I will use the picoammeter to vary the voltage while simulataneously measuring the current ..
Ok I will go through the links provided above .. Thanks ..
08-26-2014 01:13 AM
09-18-2014 03:32 AM
I know it has been sometime since I updated this post ..
So here it goes ..
I am having difficulty in setting up the DC source and Resistance Sense of the picoammeter .. The program i wrote for current measurement only is not giving any errors (will be checking that in a day or two)
With Resistance I am constantly getting an error that parameter 2 is out of range (error in measurement function)
Error in Resistance Sense:
Possible reason(s):
Driver Status: (Hex 0xBFFA0010) Invalid value for parameter or property.
Secondary Error: (Hex 0xBFFC0002) Parameter 2 out of range, or error occurred while setting Parameter 2.
Elaboration: Measurement Function
With DC Source can you tell me the difference between "Configure Source Bias" and "Configure Source DC"???
Also the Picoammeter has two functions Voltage .. It can be DC or Sweep .. Which VI can be used to interchange between the two?
09-18-2014 01:11 PM
So here it goes ..
Possible reason(s):
All this information is in the manual for the instrument. READ it.
