01-12-2017 11:09 AM
I am missing the IVI and NI Visa .NET DLLs. This is both on a new system and a system that was updated 1/2/2017 using the latest patch (16.0.1)
David
01-13-2017 10:24 AM
Hi David,
If you do a modify install on your NI VISA driver, you should see an area to install .NET support. If you select to install .NET support, it should install the appropriate files.
01-13-2017 10:55 AM
Hi Andrew,
Thank you so much for your answer. I wish it were so easy. Nonetheless, a fair answer for commencing this conversation.
The specific reply to your comment: Elementary Watson--done that already: the installer reports 'nothing to install'.
I think getting the answers to both original questions could serve others as well: (1) is this a known issue; (2) which package from the CD (NI4882_1600f0.exe) can be run with the /reinstall option to recover these two missing files without having to run the full installation?
Thanks again!
David
01-13-2017 03:35 PM
Hi David,
1. It is currently not a known issue. I tried running the patch on my computer, and my IVI.visa.dll and NationalInstruments.Visa.dll were still able to be found.
2. If it's believed that your VISA driver may be missing files, I would suggest running the full VISA installation to be certain there aren't other files that may have been deleted or corrupted. I would suggest doing this with the NI VISA from our downloads page rather than through NI-488.2 reinstall.
NI-VISA 16.0
http://www.ni.com/download/ni-visa-16.0/6184/en/
01-13-2017 07:08 PM
Hi Andrew,
Running 488.2 setup with the /reinstall option restored the files. I take this to mean that somehow the files got zapped after the initial installation; a mystery to be left behind while moving on.
I'll follow your advice on using the NI-VISA installer next month when I expect a new release given the semi-annual schedule. This will mean running both NI-488.2 (w/o VISA) and NI-VISA, which is okay. .
Best
David
