NI PXi instrument list that have built in SCPI parser
Looking at implementing a NI based PXi station that mimics our hardware bench setup for production testing. Our hardware bench instrumentation is driven by MatLab and all of the instruments are SCPI based. Our MatLab code sends SCPI "strings" to the instruments for command and acquisition. Is there a list of NI PXi instruments that have a built in SCPI parser? If not, do you know if MatLab supports IVI drivers for NI PXi instruments?
(3,154 Views)
Accepted by topic author pcbguy
hi pcbguy
check on this list of NI hardware from the mathworks webpage
https://www.mathworks.com/hardware-support/nidaqmx.html
As for the SCPI - compliant hardware, I would ask sales from NI and look for the PXI that works on your application, NI has a lot of instruments, so it would be better to look for a hardware that does what you want and then check if it has a built in SCPI parser or if it can adapt to your project
(3,116 Views)
