NI RT 8861 - Display Console output on Host PC through Serial Port
I am trying to view the console output from my NI RT 8861 using a Serial-USB port connection to Host PC. When connected through PuTTY session on the Port (COM5 in this case), the console is empty. I have all the relevant Start-up settings in NI MAX for the PXI chassis
When connected through Display port1/2 from the chassis and de-select the Enable Console Out option from the start-up settings in chassis, I can clearly see the output from Real-Time system
I am not sure if I am missing something or the PXI chassis does not have the capability to spit the console output via Serial-USB connection. Please advise.
Message 1 of 1
(929 Views)
