12-31-2016 07:23 PM
The standard C examples compine and link ok, but none so far seem to communicate with GPIB0.
I am using visual C, and the command line in the readme for the build:
cl /I"%NIEXTCCOMPILERSUPP%\include" FindInstruments.c "%NIEXTCCOMPILERSUPP%\lib32\msvc\ni4882.obj" /MD
no compile errors (I did coment out conio.h, it is not in vs c anymore?)
output after the run:
Error : Unable to open board
ibsta = 0x8100 iberr = 5 (ESAC)
Cleanup: Taking board offline
I can talk to the adapter with all the other tools in the install, and see my instruiments.
Compiled console examples can not find the USB adapter.
Any ideas?
Randy
01-01-2017 10:32 AM
Hardware? Driver version?OS?
And, why are you not using VISA? (It's everywhere you want to be)
01-01-2017 02:30 PM
Hardware is a NI GPIB-USB-HS, and it works fine with all the pre-built NI applications (NI MAX version 15.3), and I can connect to instruments, etc, so the interface is fine.
The GPIB-USB_HS driver version is 15.5.0.49152
My OS is windows 7
It sure seems that a 100 line c program example from NI should work out of the box, but it does not.
Why not VISA?
I am hoping to make the PC act as talker/listener, not a controller, but act as an instrument.
