06-03-2014 01:34 PM
I am a complete novice with Labview, as in I just started fidling with it today, so sorry if any of these questions are obvious.
I will be working with an Omega CN8202 temperature controller. As noted in the topic title, the one being used uses serial communications and the RS-232 protocol. However, the version of LabVIEW being used is from 2007, so I don't think any of the drivers here would work
I only want to be able to set a temperature on the CN8202 from a computer and don't need to do anything regarding ramp or soak times. How could I edit the drivers so that they would work in the 2007 LabVIEW version?
06-03-2014 02:20 PM
06-03-2014 02:33 PM
Right, okay, I'm not quite sure what version I have, but it's older than 2008 and updating it isn't really an option as there isn't a way for it to connect to the internet.
06-03-2014 03:10 PM
06-03-2014 03:14 PM
Oh I misread, I thought you meant updating LabVIEW itself, which I can't do since the computer that has LabVIEW can't connect to the internet.
Thanks for your help!
