11-01-2016 03:08 AM
Hi specilist ,
When I run XX.exe which use NI VISA control , it ended and the infor
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: RFPowerTools.exe
Problem Signature 02: 2.9.7.0
Problem Signature 03: 5790f049
Problem Signature 04: NationalInstruments.Visa
Problem Signature 05: 15.0.0.49152
Problem Signature 06: 557b0c22
Problem Signature 07: 1b
Problem Signature 08: 11
Problem Signature 09: Ivi.Visa.NativeVisaException
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
I re-install NI488 and NI VISA driver , the problem is still there , do you know how to fix it ?
11-02-2016 10:02 AM
Hi liuyuan1981,
What program is the XX.exe you mentioned? Are you running an executable that you created, or do you have access to the LabVIEW source code? Also, have you installed drivers for the RF Power Tool?
Josh S.
Applications Engineer
11-02-2016 06:52 PM
hi,
The software developer give me a .config file ,and it is solved.
thanks alot for your help.
br
