05-23-2006 04:24 AM
05-31-2006 05:09 AM
Any sensor with an voltage output conditioner will do the job.
We use rotronic HYGROCLIP.
If price matters, have a look at the sensirion sensors with digital output, they will use the DIO lines but need more software written.
06-01-2006 08:40 AM
08-29-2008 07:49 PM
Although use this configuration 4800,N,8,1 there is not any data coming from the testo humidity sensors.
I`m using the testo 400 with 2 channels, I downloaded from the Testo webpage a kind of code, but; they don`t work with the serial port,and if i try to use the Labview example of receiving and sending signal from the serial it doesnt show anythin??
Any ideas??
08-30-2008 04:01 AM
09-01-2008 06:41 PM
I already check the cable, it is a RS232, I try to set a conection using hyperterminal, but nothing comes from the serial port.
A long time ago I was working with sartorius balances, and in that time at the beginning I was getting strings of unreadable characters of ASCII code, after I read some posts I just had to set the parameter in the string code and started working.
For me, someting related to the format flow in Testo sending data is not right.
09-01-2008 11:21 PM
Hi
If also hyperterminal does not work, try another type of serial cable.
basically 2 types and a lot of subtypes exist.
The two types are straight and twisted, where twisted normally is called a null modem cable.
This one works when both systems use the same pins to send and the same to receive data.
09-08-2008 04:46 PM
Hello again, recently i found in the Indian Testo website http://www.testo.de/online/abaxx-?$part=PORTAL.IND.Applications&$event=show-from-content&externalid=... some code for many applications, one of them was for Labview.
Something different is in the approach that they use, they don`t work with the serial port, instead of that; they use the properties node and the invoke node. I downloaded and when I try to run them, they seem to be broken.
I`m not an expert, but when I try to fix them nothing seems to work, where did they find these invoke nodes?????
09-11-2008 06:17 AM
Have you installed toolbox?
I have tested the program labview with Testo 350 M/XL testo 454, it works for the control unit and 2 loggers, but not for analyzer box.
Lily
09-11-2008 01:21 PM - edited 09-11-2008 01:24 PM
