Subsequent delayed analog voltage generation with USB-X 6343 or 6353
Hi Andrew,
In the code, I did not specify any sampling rate. You can see the partial of my VI responsible with the time delay task. In this part, firing low and high times are 1.2 ms, injection high and low times are 1 ms. Injection delay varies between 1 ms and 0.1 ms. As in the previous thread that I wrote, I checked the code and hardware with an oscilloscope and posted the results. According to results, it was ok.
Egemen
Message 11 of 11
(949 Views)
