01-08-2016 01:56 AM
TDS784D and NI GBIP-USB-HS
Problem: GPIB (and soft) do not see an oscilloscope?
The interface is operating other equipment are shown and oscilloscope TDS784D shows the configuration of the BUS OFF ?
The menu NI also do not see the oscilloscope.
Advanced Settings ? Bus settings ?
Paraller Bus Durration : 0 uSec ?
Bus timing : : 2 500 nSec ?
Does anyone know how to solve a problem or knows the problem ?
01-08-2016 06:00 AM
max-bit wrote: oscilloscope TDS784D shows the configuration of the BUS OFF ?
Sounds like you need to go into the menus on the scope and turn on the GPIB bus and make sure it has a different address than any of your other instruments.
01-08-2016 06:24 AM
The GPIB bus is OK and There are no collisions in port numbers.
01-08-2016 06:54 AM
01-08-2016 07:29 AM
1. Sorry but I do not need help here "look in the manual"
2. The manual says nothing about this, exactly -unfortunately.
3. I suppose that the problem may lie in the compatibility of interfaces and the advanced settings.
01-08-2016 08:50 AM - edited 01-08-2016 08:56 AM
If you can't be bothered to read the manual, then no one here is going to do it for you, because it isn't our problem. It is YOUR problem. You had better get that through your head fast.
Oh, and your #2 is WRONG.
01-08-2016 09:00 AM
That's what this forum is?
I want to know if anyone had a similar case.
And I .... (you know where), type text find yourself in a statement.
If you were to issue described in the manual that I would have found him.
Understand?
01-08-2016 09:07 AM
01-08-2016 01:34 PM - edited 01-08-2016 01:35 PM
Even some stupid useful expressions?
So hopeless forum have not yet seen.
01-08-2016 02:13 PM
