09-17-2020 10:51 PM
When I Measurement & Automation Exploer to scan GPIB-USB-HS, It indicates that there are too many gpib listeners, and what should I do?
PS:
It is ok when I reseat the GPIB
09-18-2020 05:56 AM
Based on your "ps", it sounds like your issue is fixed. Sounds like it was a loose connection on the bus.
Are you still having an issue? How many devices are you connecting to?
09-20-2020 06:07 AM
09-20-2020 06:03 PM
@Vinson12138 wrote:
- if loose the connection on the bus,the NI-Max should prompt disconnection not too many GPIB listeners?
Not if the GPIB connection was loose. That could introduce noise making it look like multiple devices were trying to respond.
